PostGIS Writer: Fanout for feature type '____' failed to find feature type template '___')
Badge +10
I am getting this error when using the dynamic Postgis writer
error ( PostGIS Writer: Fanout for feature type 'gcenter_Governorates' failed to find feature type template 'gcenter_Governorates')
I am Using the FEM 2018 build 18305, as sugested in diffrent artical the issue was solved , in this version , but still it s not working
attached a snap of the writer config
Best answer by takashi 28 May 2018, 00:02
Userlevel 3
If you intend to configure a dynamic workflow according to the discuss in the previous Q&A;, most likely the Dynamic Schema Definition parameters setting is wrong. Check carefully the screenshot I have posted here.
Besides, the current FME has a defect regarding the Table Qualifier setting in a dynamic writer feature type configuration. See also these threads.
Userlevel 3
See also this article, which is linked from the article - Tutorial: Dynamic Workflows I introduced already in the previous Q&A.;
