This morning I worked with FME Desktop V2017.1.0.0 (b 17539). Suddenly I get a message:
Creating reader for format: Oracle Non-Spatial
File D:\\apps\\FME\\metafile\\.fmf could not be opened
I read in the known issues
We've fixed this issue for FME 2018.1. This issue was a problem with showing Oracle table list in the DatabaseJoiner.
Ik have the same message with SQLCREATOR.
- wich metafile FME tries to open? Can we replace this missing file?
- Is this the same error in DB Joiner as I also have in the sqlcreator?
- is there a workaround available (I have tried to create an new DB joiner and even copied the whole WS to a new WS and replaced all DBjoiners but that does not work).
(- install fme 2018 will happen in a month or 2, but I can not wait so long or I have to escalate this issue to our manager with priority.)
thank you for your reply
Best answer by perry
