GML to KML
  • 24 August 2018
  • 20 views
Badge +11
I'm having some difficulties converting a GML to KML/KMZ while using the automated Generate Workspace. I've tested GML with https://mygeodata.cloud and it converts properly, what setting is missing?
I've attached the GML, KML produced by FME and KML produced by MyGeoData.cloud
Hi @hlouie,
You're probably missing the CRS information in the GML reader and KML writer. See attached files.
gml2ogckml.fmw
Badge +11
Bingo, the key was your GML SRS Axis Order of "1,2".  Look like FME default is "2,1"
The default axis order for EPSG:4326 is 2,1.
Glad to hear that it works. Thanks for the info about the default axis order for EPSG:4326, I was not aware of that.
