I am migrating from FME 2014 to FME2017x64. We have been using a workbench for some time in which the output includes writing to a number of excel template worksheets having defined ranges for the writer. In each case the option to truncate the range has been set to yes. When running the same workbench in 2017x64 I am now seeing that some worksheets/ranges are getting populated while the vast majority are not . I've been looking for something that indicates why some would get populated while others would not but have not been able to determine what that might be. Has anyone else experienced problems with excel writer in FME 2017 not writing to worksheet/ranges as they had in a previous version?
Hi @wallace,
Interesting find. Thanks for sharing. I've seen FME have trouble with some of the Microsoft 'theme' colours - this could partly be the problem. If you have a sample template file which you can share with us where you've found the issue I will pass it along to out dev team to take a look at. Sorry to hear about the trouble
Hi @wallace,
settings from Truncate Sheet/Named Range = Yes to No and Drop Sheet/Named Range = No to Yes and get more output generated, though the formatting does not adhere to that of the template file. This seems to defy the documentation I've read on how this should work. http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/xlsx/XLSX_writer.htm and http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/xlsx/xlsx.htm. Not sure which versions these instructions apply to? I'm running the workbench on 2017.1 Build 17539. Where should I send the template file I've generated from the workbench? Its a littlr over 2MB in size.
Hi @wallace,
