Linear referencing: How to create point/line geometry from route event table?
  • 27 March 2018
  • 6 replies
  • 30 views
I need to create a point/line geometry out of the following input data:
a) route: line geometry stored with measure values, including a route id field
b) point/line event table without geometry, including a reference on the route id field, a measure value field (point event) / a start and an end measure value field (line event)
Is there an existing transformer or a common known routine in FME to solve this problem?
Best answer by david_r 27 March 2018, 17:26
Badge +10
Here's a great example of how to use Linear Referencing in FME!
I you merge the two input datasets (FeatureMerger on the route id), you can use the Snipper with snipping mode = "Measure (value)" to "snip" or to cut your route geometries to a start/end value.
Thanks for your help and the sample workbench. This worked well!
@david_r Can I get a copy of the sample workspace, too? I need to do the same thing.
I'm sorry, I don't have any sample workspace for this.
But feel free to post your case as a separate question, I'm sure someone can help.
Here's a sample of how I solved it (comments in German).
