I'm writing a custom format reader to read our custom point cloud format. The sdk is not clear on how to add points to a point cloud. I only have 4 components x, y, z & intensity.
Hi @ma2cdw
have you tried FME PointCloud XYZ Reader? Can it be used to read your custom point cloud format?
Hi @ma2cdw
Thanks for the suggestion. I have tried that, unfortunately, the files store several blocks of scaled offsets. The origins and scales for each block are stored on an SQLite database along with the index of the start point and the number of points in the block.
Hi @LenaAtSafe,
Would maybe PointCloudTransformationApplier be helpful?
Would you have a small data sample? I don't think I fully understand your data.
SELECT DISTINCT BLOCKIDX, LASERBLOCK.LASERID, X, Y, Z, SCALE, NAME, FIRSTPOINT, NUMPOINTS, LINREF FROM LASERBLOCK JOIN FILE ON LASERBLOCK.FILEID = FILE.ID JOIN LASERLOD ON LASERLOD.LOD = LASERBLOCK.LOD WHERE LASERBLOCK.LOD = 4 ORDER BY LASERBLOCK.LASERID,LASERBLOCK.BLOCKIDX
Each block gives you a filename, a point index where the block starts within the file and how many points there are within the block, the centre of the block in real-world coordinates and a scale factor for the x,y&z; offsets from the block centre stored in the laser6 files.
The laser6 files are not straightforward XYZ files so I have attached some c++ code for reading them. If it's of any help.
fme-os3d6-reader.zip
The PointCloudTransformationApplier could be useful if we can pass the centre coordinates and scale to it.
