PNG Batch Rotation
  • 2 January 2018
  • 5 views
Badge +14
I have a png (map symbol) that I'm trying to rotate for each degree (so I end up with 360 for each symbol), but when I use the Rotator, it just makes the image size bigger at certain angles. Is there a way to ensure that all the angles get resized back to 60x60 so they all appear the same size on the map?
(0* is 60x60)
(60* is 82x82)
Badge +7
Hi @runneals,
Thanks for your question. I'm not sure if this is the perfect solution, but if you use the 3DRotator instead of the Rotator, you should be able to rotate your PNG around its centre point, and then clip it using the original (**connection from original to Clipper port is hidden in the image below). Some of the raster properties aren't clean in the output, but the extents seem to be the original 60x60.
Hope this helps,
Nathan
