How to write XML metadata to Esri Geodatabase (ArcSDE Geodb Raster Dataset)?
  • 13 September 2017
  • 10 replies
  • 44 views
For a project I’m trying to use FME to directly write XML formatted metadata, stored in an attribute, to an ArcSDE Oracle database with FME.
Following these examples (1&2), It works fine with a SDE Feature Class & the Esri Geodatabase (ArcSDE Geodb) writer.
However, for a SDE Raster Dataset I’m experiencing some difficulties:
  • The Esri Geodatabase (ArcSDE Geodb) writer won’t let me write to SDE Raster Dataset
  • The Esri Geodatabase (ArcSDE Geodb Raster Dataset) writer doesn’t have the option to set the allowed geometries to geodb_metadata.
Does anybody have experience with this issue (and perhaps a solution), or am I doing something wrong?
Userlevel 4
Badge +13
Hi @thomas_merkus, using the Raster format, if you were to create the geodb_type attribute and set it to "geodb_metadata" (as in Writing XML Metadata to Geodatabase), are you able to write successfully?
Badge +8
Hi @thomas_merkus What error do you get? And does this help? My guess is that you should use the FME parameter geodb_type to set to geodb_metadata, not the geometry type.
Thx @helmoet & @TiaAtSafe! Yes that is the same method I tried. I noticed that in some cases it actually works and in others I got an error message. Moreover, I was wondering if this is the correct way to do it. The errors are then probably due to some other issue.
Userlevel 4
Badge +13
What was the error message(s) you were getting?
@helmoet @TiaAtSafe The workspace error is:
|ERROR |Error occurred using IXmlPropertySet2::setXml(). HRESULT = -2147215103. File: geodbutilities.cpp Line #: 2881
It only happens for certain raster datasets, while others work fine.
Badge +11
@Thomas_merkus, were you able to debug your problem? I have a similar error for a vector featureclass and only on this featureclass in two different SDE databases.
@tnarladni, Not yet unfortunately. Although, I have not tried writing directly into Oracle instead of SDE, but that might be more of a workaround.
Badge +8
Hi @thomas_merkus, here is where I quit. Might be an idea to submit a support call at Safe's?
Userlevel 4
Badge +13
@thomas_merkus please do submit a case if this is still causing your grief. You can submit a case along with the workspace and log file here .
@helmoet @TiaAtSafe I have submitted the case. I'll keep you updated!
