Notification management / IMAP Protocol
  • 8 September 2017
  • 0 views
Hi Folks,
I have tried - without success to use Notification in FME Server (version 2015.1.3, customer's one)
I have used IMAP protocol, following Safe documentation :) as follows :
I begin with creation of a topic
(see attached image1)
Testing it, it’s ok.
Then creating a publication named “IMAP Email” with these parameters :
(see attached images 2 and 3)
Then I monitor the topic, send an email to the address , but nothing is detected …
I activate on my gmail account the IMAP protocol too …
Control that the port 7078 is open ….
I have (of course) the same problem with subscription (in fact, my emails are never detected by FME Server)
I need to show this part of the configuration on the next training in the 19 and 20/9, so don’t know what to do .
do you have any idea about it ?
regards
Pascal Mortz
1Spatial Lyon, France
pascal.mortz@1spatial.com
Badge +10
Hi @pascalmortz,
I just wanted to confirm that the email address you are using in the publication is not as the screen shot shows.
Userlevel 1
Badge +11
@pascalmortz I think Richard is on to something. Also... have you looked at the FME Server logs to see what is being reported there. Unfortunately, the UI in 2015 may not be showing feedback confirming the configuration is correct.
