how to adjust writer to a flixible folder?
  • 16 September 2019
  • 1 view
HI,
how can I adjust the writer, so I can specify the destination folder every time different?
I have the same Workspace, but I need to write the results all the time in the other Folders. I do not want to create/add all the time a new one. And I need to publish it into a Server, so the writer, and also the reader need to be a flexible.
Badge +16
Hi @terezia86,
How about using a published parameter for the folder destination?
Hi @terezia86,
Hi @itay,
thanks for your respond. I´ve read the article about Parameters from you, and it worked perfectly. Thanks a lot for an idea!
Badge +16
Hi @itay,
Glad I could help.
