Creating ESRI Vector Tiles in ArcGIS Online sing FME
  • 23 August 2019
  • 47 views
Is it possible to create ESRI Vector Tiles in ArcGIS Online using FME.
I'd like to read from a database feature class for example, and keep an ArcGIS Online Vector Tile layer up to date with period updates.
I can only seem to create and update ESRI Vector Tiles in ArcGIS online from ESRI PRO or possible write a script in Python3 and use the ESRI GIS API, in which case I don't really need FME.
Good question! I have this same need / question.
Badge +2
any solutions to this?
Hi @dparsons42​ , @mmirobelli​ and @t_hohenstrater​
I am not overly familiar with Esri Vector Tiles, but I did find this older post which links to an Idea for ESRI Tile Cache Files if this is what you are looking for be sure to add a vote to the idea, this will help with the chances of it getting added to a new build of FME in the future.
