Hi everybody,
I try to assign a specific layer for several attributes in a block Acad (in order to respect our CAD standard).
I try to assign dedicated layer with the "Attribute manager" (see attachement), but when the acad file is created, I've only one layer defined by "Layer Name" in DWG Writter.
Following documentation, it should be possible to acces this kind of information:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/acad/Inserts.htm
But in my case, it doesn't work ... any help ?
Eric T.
Sa, after several test, I've found a solution.
I provide this, in order to help other users :-)
I've create something ...create_acad_blocks_with_attributes.fmw
If these are dynamic blocks, FME can read the blocks and attributes, but not write them.
A PR is in the system to add this to the DWG writer, but it has not yet been built.
I have run into the same limitation.
Adding your vote to this Idea might help: Dynamic blocks
Use internal FME attributes 2 Answers
DWG layer description 3 Answers
Storing CAD Symbology in attribute 2 Answers
Maintaining attribution when transforming GIS to CAD 5 Answers
Shapefile to dwg becoming a block and losing attribute data 2 Answers
