How do i configure FME Server 2019 for Server Apps to work?
  • 6 August 2019
  • 3 views
I'm testing FME Server 2019.1, We created a test workbench that does nothing really and created a server app for users to test. We get an error. "There was an error submitting the job. " Anyone know what i should look at and/or the help documents relating to this configuration?
Best answer by brianapeters 6 August 2019, 18:25
Trent (From support chat) gave me a couple good articles.
A few good articles for troubleshooting a job not being submitted correctly can be found here, if you can take a look at them:
https://knowledge.safe.com/articles/55057/fme-server-troubleshooting-submitting-a-job-in-fme.html
https://knowledge.safe.com/articles/49624/fme-server-and-https-troubleshooting-guide.html
To add to this issue.... I can not run workbenches from the repository. I can although run them inside a scheduled job? There is no security errors with the certificate. I went line by line with our production server to compare. Permissions and security and everything is exactly the same?
Mind boggling....
