I am trying to solve the problem with dangling roads in the network.
Given the input of the roads, I simply ran it like this:
I assumed that the topologyBuilder would give me _node_angle{}, _node_angle{}.fme_arc_id and everything else, as per the docs,as the edges are perfect, but it seems that there is a challenge somewhere, as only _node_number is shown.
Hi, in FME 2019, generating the list attribute has become an option. Make sure that the "Generate List from Input Edges" is checked.
"List Accumulation
Generate List From Input Nodes Gives the option to create a list on the Face and Edge output ports that relate to information from the input nodes.
Generate List From Input Edges Gives the option to create a list on the Node and Face output ports that relate to information from the input curves.
Generate List From Input Faces Gives the option to create a list on the Node and Edge output ports that relate to information from the input faces." -- TopologyBuilder Help in FME 2019.1
Here is how the node looks
and the edges
As you can see, the edges indeed have everything, but the nodes do not have all the other attributes. I wonder if the network is not properly built or something, but I have tried this with another road network, and same results.
Connect Adjacent 3D faces - Topology Builder Problem 2 Answers
Finding Connectivity within a network between nodes 1 Answer
topology builder create nodes/lines on intersections even data is clear !! 2 Answers
Topology Path issue. Getting the path to a hub. 2 Answers
Extract line segments between two points 3 Answers
