Intersected polygons and select highest related candidates for each combination
  • 23 July 2019
  • 1 view
Badge +1
Within more than 2500 Features in one Polygon shapefile I used a SpatialRelator Transformer to find out intersected polygons followed by ListExplode Transformer. The result as following example:
My target is to select intersected features of highest related_candidates number (3 for above example). In some cases the highest related_candidates is 4 or more.
Does anyone have any ideas or potential solutions?
@mark2atsafe @egomm @david_r @jlutherthomas @jdh @takashi @redgeographics @danilo_fme
Best answer by caracadrian 23 July 2019, 14:08
Badge +20
You can use StatisticsCalculator with GroupBy set to FeatureID to get a maximum of the attribute you want followed by a TestFilter set to _related_candidates = _max_related_candidates.
