hello,
i have a excel document that i want to change with fme.
What i want is that colum A, B, C, D and E are copieed to another file if there is a value in a certain date (of colum F........till...AC)
Here is the result that a want: U will see that a want that a row will be copieed if there are more values of a diffrent month, see row 20 and 21.
i hope that u understand it, the document of excel is attached
it worked perfect thanks!
i also add a cloner to split a row on a value (higher then 1), so u get multiple rows of the value is bigger then 1
Text file attribute to Excel file. 1 Answer
Working with 2 Tables using FME 1 Answer
Append Comma Separated values of One Column 2 Answers
Excel writer: Number stored as string 1 Answer
Excel output formatting 1 Answer
