I'm using fme desktop 2018 (18586) on ubuntu 18.04 and that was working perfectly. After an update on the system, fme workbench isn't initializing anymore but the other applications are working fine(data inspector, license manager, and quicktranslator)
I suspect that your OpenJDK 8 has been removed. Please run
ls -l /usr/lib/jvm
and post the results here.
If OpenJDK 8 is not listed, use your package manager to install it (or simply reinstall FME) and try running FME again.
If OpenJDK 8 is present, run
/opt/fme-desktop-2018/fmeworkbench
from the command line and post the output here.
Finally, if you can provide any info about the "update on the system" that might be a factor it would be much appreciated.
Find the Total Production (total sum) with 40 years of monthly data. 2 Answers
fme fills polygons and circles 1 Answer
FME on Ubuntu 16.04 Install 3 Answers
Create lines from points 1 Answer
Listpopulator with 2 prefixes 3 Answers
