I am working on FME 2019.0.1 I am trying to find out a center line(Approx. Center Line in FME 2019) of the polygon in the below geometry. The polygon is the input and polyline is the output.
I tried using Generalizer with Douglas(Generalize)with varied Tolerance (after using converting it to LL-84) and McMaster (Smooth) and above is the best output. In the ideal scenario, the output should look something like below:
Basically, the polylines touching the center end parts of the polygon.
My approach: Create a bounding box. Put weights at the points touching the polygons. Join the polyline output at weights. Will that be a possibility? I have still not worked on it. Just an idea.
Any other ideas I can work upon! Thanks.
