Height adjust according to correct one
When we draw the big river line in both edges, each side we have to draw in same height is too difficult.
my question is, we draw one side in exact height ,another side we draw not in correct height.using FME how to correct the incorrect water line to correct height according to exact waterline ?
The question isn't entirely clear. Can you maybe post a screenshot or an illustration of what you need?
Userlevel 1
Badge +10
As @david_r suggested, it would be helpful have some further details. It might also help to know what formats your working with, and what is the source for your "exact waterline"... are you wanting to use the first "edge" that is of exact height has your reference for the second edge, or do you have another waterline dataset that intersects or you can join to the the second "incorrect" edge? Do you have sample data that you can share?
