Hello all,
I am struggling to get the CAD layer attributes that are associated with my DWG drawing to come into PostGIS.
Initially all I want to do is get the DWG into PostGIS with all the associated CAD attributes, from there I will then use it to do more validation but I am stuck just getting the first part to work.
I have a DWG reader that writes each layer to the same layer name in PostGIS but not sure if I am missing something either in FME or in the set-up in PostGIS. Currently all I get is the lines or points but all the attributes are empty.
Any assistance would be very much appreciated.
Hello @deanhowell2009
What is the attributes in the PostGIS? Did you mapped on the Writer, like this:
Danilo
Thanks Danilo, I failed to the attributed matched correctly as I was assuming that the attributes from the reader would just flow automatically through to the writer but you need to go that extra step to set the value of the attribute. I am off and running now thank you, although I do suspect that there might be a more streamlined way of doing it.
Case insensitive field names 3 Answers
Best practice for checking attribute values 6 Answers
Can I influence naming of kml file inside kmz 5 Answers
Join 2 columns 3 Answers
How do I compare tables with mismatching schemas when using the UpdateDetector? 1 Answer
