Working with esri and the developers for ArcGIS Online, we came up with this script that can be used on shutdown. You will need to write data out to a zipped file geodatabase (or other formats), then configure the script.
Only works with 2019.x+ as it requires you to use ArcGIS Pro (tested in 2.3). It does take a while to run (as it has to use the ArcGIS Python library), but is SUPER efficient when trying to write LARGE datasets to ArcGIS Online. It is much preferred over using the FME writer because that one uses the traditional database insert for each record while this is similar to bulk inserts. Can probably be modified for writing to Portal as well.
https://github.com/runneals/GISProjects/tree/master/agol/Append
cc @carsonlam @bruceharold @mmccart
