Hi, I am trying to create a KML output which extrudes building polgyons and overlays a Flood Map. Unfortunately I cannot get an output with all of the polygons in a uniform color (see attached image), does anyone know how I fix this issue?
Aaron
Are you creating the building polygons in the workspace using an extruder (as opposed to the above example where 2d polygons are given a z value and the kmlpropertysetter is set to extrude)? If you are creating the 3d polygons in the workspace then in the advanced writer parameters you want to have "Write 3D Geometry As Polygons" set to yes.
The alternative is to use an AppearanceSetter to control how the features appear in the KML
Hi, Yes I was using an extruder, alternatively I was advised to use a KMLPropertySetter which has subsequently resolved my issue, thanks for your suggestion!
Hi @aaron_oakes13,
You could use a KMLStyler transformer to style your KML file.
This is also used in the FME Desktop Basic training: https://s3.amazonaws.com/gitbook/Desktop-Basic-2018/DesktopBasic2Transformation/2.Exercise7.html
Sorry @arnovananrooij, I didn't mention I was already using one, this still does not fix my issue. I have attached an image of my current KML styler set up. Cheers
How can I change the colors for a KML line when it is rolledover or selected? 2 Answers
KML styler for 75K points? 2 Answers
Custom icons in KMLstyler 1 Answer
Cannot find KML reference ICON 2 Answers
KML Styler Custom Icon 2 Answers
