For context;
643,312 features in the road network
13,539,080 From-to lines (these are all 2 point lines)
Progress so far;
344 ShortestPathFinder_NoPath
no other output
My expectation is that ShortestPathFinder should be sending lots of output to ShortestPathFinder_Path but there is none. Is this normal behaviour? Does the transformer save up the output until the end of the process?
Should I kill the process and try to tweak it? I would lose 48 hours of processing time if I kill it
If there was a constant stream of output to ShortestPathFinder_Path then I would be comfortable that progress was being made, but there is not
