I need to validade if the sum of the numbers is pair or odd.
How to make this?
You can use a Tester with this test:
@Value(_your_number)%2 = 0:
Passed: even numbers
Failed: odd numbers
use this syntax with version 2021.1 : @fmod(@Value(_your_number),2)
