Today I wanted to experiment a bit. I used WorkspaceRunner with "wait for end" option set to no.
It worked quite well for some time, I had few hundreds of featured to be processed using this, but after some time it all slowed down and then stopped.
Then I stopped job in fme workbench and tried to run it again. There was information that I dont have enough licenses.
I saw that problem before so I thought that it would be enough only to open task manager end kill some fme.exe processes but there were none.
Then I opened powershell and entered get-process command
Here there are.
When I try to kill any of those processes it doesnt work, still list is the same
Do you know that problem? I hope that there are better ways for solving that then computer reboot :)
Hello @redgeographics
Thank you for reply. The problem is that main workspace was manualny terminated and right now I can't kill those child processes like I described im the question. They don't use any resources and already've been there for 20 hours. I can't kill those processes using task manager or cmd or powershell. The only way to terminate them that I know is to reboot machine but maybe you know different way?
