I am using FME Desktop 2017.1 and trying to output a Microstation V8 DGN file with curves instead of line strings. I have exposed and set the igds_type attribute to 11 (ie: curve) but the output DGN now has no lines at all. Does anyone have any ideas?
Hi Dave actually I just worked out the answer myself! I needed to set the igds_type attribute to "igds_curve" rather than "11".
Maybe a silly question, but have you verified that the FME geometries are indeed arcs and not polylines when arriving at the writer?
Hi @david_r I have another issue with the igds_type curve output in Microstation. For some reason, the first two and last two vertices of every curve are not joined together when I output the file to Microstation DGN. Do you know why this would be? They were definitely joined together when I used a normal line_string...
Microstation DGN igds format attributes 3 Answers
How can I set the Line Length of a DGN Text element/node? 1 Answer
Microstation DGN curves not joined at first and last two vertices 2 Answers
Combine Microstation Tags and Cells into a Graphic Group 0 Answers
How can i read the DIMENSION parameter of a DGN to determine if a dgn file is 3d file or 2d file. 5 Answers
