Hi, I have a shapefile that contains polygons and we would like to find the minimum width of each of the polygons. Any help would be greatly appreciated. Thank you.
+3
you could try create centerlines (can crash on complex shapes and donuts etc. ). Clean em up.
Chop by 2. Rotate pieces by 90 and then extend the line both sides by a sufficient large amount.
Line on area, clipper etc. Add length value.
Statistics calculator on length value grouped by object id.
