Hello there 'I am reading a XML file , and looking to expose the hidden attribute
as you can see in the Pic
I tried attribute expose and list exploder but it didn't work
How did you configure the AttributeExposer? You will have to expose the following attributes:
FieldInfos.SubtypeFieldInfo{}.DefaultValue FieldInfos.SubtypeFieldInfo{}.DefaultValue.pos FieldInfos.SubtypeFieldInfo{}.DefaultValue.type FieldInfos.SubtypeFieldInfo{}.DomainName FieldInfos.SubtypeFieldInfo{}.DomainName.pos FieldInfos.SubtypeFieldInfo{}.FieldName FieldInfos.SubtypeFieldInfo{}.FieldName.pos FieldInfos.SubtypeFieldInfo{}.pos FieldInfos.SubtypeFieldInfo{}.type
The ListExploder should then let you select the list "FieldInfos.SubtypeFieldInfo{}".
Notice that there are no numbers in the {} brackets.
XMLReader list creation 1 Answer
SpatialRelator propagates wrong feature type ? 1 Answer
Explode lists with a minimum of transformers 2 Answers
permute a list, output to csv 1 Answer
Show differing attributes between two touching features 2 Answers
