Hi All,
I'm trying to apply geotiff imagery to 3d roof geometry with the Top Down Georeferenced method (using Attribute Join within the transformer). The geometry is rejected and encoded with the MISSING_REFERENCEE_KEY string.
Any help is much appreciated!
Charles
Appearance cannot be set onto Polygons. Try inserting the FaceReplacer before the Aggregator to replace each Polygon with a Face.
