Python getAllAttributeNames - order?
  • November 21, 2018
  • 5 replies
  • 17 views
Forum|alt.badge.img+31
What controls the order that attribute names are listed when using feature.getAllAttributeNames ?
mark2atsafe
Forum|alt.badge.img+43
  • November 21, 2018
Would getSequencedAttributeNames do what you need?
"This method gets a list of sequenced attribute names in the order they were added to the feature."
  • November 21, 2018
I think I have to have a schema to start with to use this, I'm trying to create a dynamic schema to use in a writer
daveatsafe
Forum|alt.badge.img+19
  • November 21, 2018
Hi @egomm,
You can get a list of the attribute names on a feature without Python, using the AttributeExploder. This might be more useful for creating a schema feature.
  • November 21, 2018
daveatsafe wrote:
Hi @egomm,
I can create the schema dynamically in python, i was just curious as I couldn't decipher what logic was being used to control the order of feature.getAllAttributeNames
takashi
Forum|alt.badge.img+21
  • November 21, 2018
I think that it depends on the implementation. If the name/value pairs of attributes was implemented with the Python dictionary and the getAllAttributeNames method would just return the list of its keys, the order would be unpredictable.
