Anybody have tips to update my python code to python 3?
  • 9 November 2018
  • 7 views
Hi, my python code below does not work in python 3, I receive a " Unicode-objects must be encoded before hashing" error message. Any tips?
import sys, getopt, hashlib, os
from hashlib import sha1
import hmac
import base64
import time
import requests
import subprocess
import json
import fme
import fmeobjects
import datetime
def calculate_signature(feature):
# get input values from feature attributes
api_key = FME_MacroValues['API']
host = feature.getAttribute('host')
method = feature.getAttribute('method')
shared_secret = FME_MacroValues['SharedSecret']
timestamp = feature.getAttribute('timestamp')
#timestamp = datetime.datetime.utcnow()
url = feature.getAttribute('url')
# set access_key
#access_key = FME_MacroValues['AccessKey']
access_key = 'A0F66A0E-0CC9-7ABE-24CC-F8807E2829AB'
# copied code from calcualte_signature
sig_block = "{}\\r\\n{}\\r\\n{}\\r\\n{}\\r\\n{}\\r\\n{}\\r\\n".format(
method.upper(),
host,
url.lower(),
timestamp,
api_key,
access_key)
print("\\n\\n -- sig block -- \\n" + sig_block + "\\n\\n")
decoded_secret = base64.b64decode(shared_secret)
hashed = hmac.new(decoded_secret, sig_block, sha1)
sig = hashed.digest().encode("base64").rstrip('\\n')
# add sig value to feature as attribute
feature.setAttribute('sig',sig)
#feature.setAttribute('timestamp',str(timestamp))
Badge +2
Hi @johnglick,
Perhaps you might find it useful to use 2to3 - a python tool to automate code translation: https://docs.python.org/2/library/2to3.html
Else this doc may also be helpful to you: https://docs.python.org/3/howto/pyporting.html
Userlevel 3
Probably you will have to modify these two lines.
Python 2.7
sig = hashed.digest().encode("base64").rstrip('\n')
Python 3.x
hashed = hmac.new(decoded_secret, sig_block.encode(), sha1)
sig = base64.b64encode(hashed.digest()).decode('utf-8')
Python 2.7
Python 3.x
works perfectly thanks!
