Hey
More of an fyi than a question. Over the past years I’ve had to do a lot of FME Server automation using the fme server rest api. I’ve created an python wrapper to help make fme server automation easier for me. Had this code kicking around for a while but recently found the time to sanitize/share it.
The code for this can be found here:
https://github.com/bcgov/dbc-pylib
There is some getting started docs here:
https://github.com/bcgov/dbc-pylib/blob/master/docs/FMEServer.md
Hoping it will be useful to someone, if so please use! If you are interested in contributing even better. If there are desired features / functionality let me know as well by posting to the issues on the github repo: https://github.com/bcgov/dbc-pylib/issues
Cheers
Kevin
