I have 1,392 .asc files that I want to mosaic into a single .asc file.
The input files are tiles of a 1m DEM.
I am using a ESRI ASCII Grid reader to open the 1,392 files together, then a RasterMosaicker to merge them together, and a ESRI ASCII Grid writer to output the result.
I get this error
Esri ASCII Grid Plugin: Fail to open the Esri Ascii Grid reader on file `\\\\podcisilon\\Groups\\Geospatial_GIS\\ALS\\2014\\LGA_Brisbane\\Products\\DEM_1m\\SW_507000_6964000_1k_1m_DEM_ESRI.asc'
ESRIASCIIGRID writer: Failed to get tile of size 1 rows by 54000 columns at row 18000, column 0
A fatal error has occurred. Check the logfile above for details
Best answer by xiaomengatsafe
