Is it possible to call API python for GRASS in a FME project?
Yes, but you need to change your python interpreter to the one where the grass library is installed.
Thank you for your answer but i try to use API python for GRASS and FME in the same project. I don't find a solution to call these together...
Since GRASS is available via PyPi you can use the instructions at https://knowledge.safe.com/articles/841/install-python-modules-into-fme.html
