The error number from ArcObjects is: '-2147467263'
  • 9 October 2018
  • 22 views
Badge +4
I'm trying to wirte to a SDE database with postgres arcitechture. I've filled in all the parameters and I get this error message:
An error occurred while attempting to open the table, feature class or relationship class 'datasetname.featureclassname'. The error number from ArcObjects is: '-2147467263'. The error message from ArcObjects is: {}
What a lovely error message from ArcObjects, right..
Has anyone experienced this, and know what can be the fault?
Ps: I couldn't find the error number here: http://resources.arcgis.com/en/help/arcobjects-java/api/arcobjects/constant-values.html
Best answer by paalped 9 October 2018, 11:26
Userlevel 6
Badge +34
Found this one?
For me it almost is caused by reserved words.
Badge +4
Found this one?
Thanks, but I can't see that there are any conflicting words.
Badge +4
The Error comes from trying to write to a SDE database which is not a SDE enabled database. It was just a clean postGIS database.
