Hello all,
I uploaded an IMDF file of for a building to Online IMDF Validator and received a validation report. But I found something wrong that some warnings were confusing because every Unit feature must has an unique ID.(below table) But it showed me that their ID were none.
I appreciate any guidance!
Thank you!
Feature Type | ID | Category | Level | Validation Error
unit | None | structure | 01ca9f36-6b0e-48ab-92c0-43af7fdb417c | Warning|Display-point not within Unit. |
unit | None | structure | 2110f506-1b2b-4679-8bd8-cef2257861f4 | Warning|Display-point not within Unit. |
unit | None | walkway | 2110f506-1b2b-4679-8bd8-cef2257861f4 | Warning|Display-point not within Unit. |
unit | None | structure | 3cb84699-b393-4bcf-ad15-06fb37fcaa55 | Warning|Display-point not within Unit. |
unit | None | structure | 671e5bc8-21b1-4227-a2bf-6ce87b013a04 | Warning|Display-point not within Unit. |
unit | None | structure | 6a6e6259-2ad1-4a21-9c05-25bd405a5942 | Warning|Display-point not within Unit. |
unit | None | structure | a10ad24d-bdf1-4e8f-9a17-24d8068dce51 | Warning|Display-point not within Unit. |
unit | None | structure | a600f9a8-e128-4bbc-bf3f-18a7f31ffb4e | Warning|Display-point not within Unit. |
unit | None | walkway | a600f9a8-e128-4bbc-bf3f-18a7f31ffb4e | Warning|Display-point not within Unit. |
unit | None | structure | bc388041-969c-4f24-8c21-bddea72b09fe | Warning|Display-point not within Unit. |
Hi @hanson,
Thank you for bringing this problem to our attention. We have fixed the problem in the Validator that was omitting the id numbers for the 'Display point not within ...' messages.
