How to export data as .js?
  • 12 September 2018
  • 5 replies
  • 23 views
I am using the QGIS plugin "QGIS2WEB" for publishing spatial data into webmaps, written in javascript. The plugin converts all the data showing into .js files, stored in a data registry. Now I want to replace/add spatial data manually, without using the plugin. Is there a way to convert and export spatial data, e.g. json as .js with FME?
Thank you.
Best answer by nathanatsafe 12 September 2018, 21:02
I don't know what that QGIS plugin expects, but have you looked at the GeoJSON writer? Could that be it?
Badge +7
Hi @pascatl
The QGIS plugin expects a .js file with the GeoJSON feature(s) assigned to a variable. This .js file is included as a script in the output .html, which calls the variable and adds it to the map. (You can verify this in your qgis2web output folder in /data.) The fact that the .html uses a .js file with the GeoJSON assigned to a variable isn't necessary for the web app to work.
It might be possible to create this kind of .js file with FME, but since we don't have a "Javascript" writer, it might be a bit of a hack. Instead I would suggest writing out your GeoJSON to a .json file with FME, and consuming that in your application.
Hope this helps!
Nathan
Hi @pascatl
Hope this helps!
Nathan
Thank you, I will give it a try and let you know, if it works for me.
Hi @pascatl
Hope this helps!
Nathan
The solution was, as you mentioned, to export the new spatial data as GeoJSON and assigning the GeoJSON to a variable in my javascript file using ajax. Instead of using the converted .js, I can now replace new data easily with GeoJSONs.
var geojson_data = JSON.parse($.ajax({'url': 'data/data.geojson', 'async': false}).responseText);
"geojson_data" is the "new" .js file linked in the javascript code.
Thank you for your help.
Userlevel 6
Badge +34
Awesome, thanks for sharing! I used this (QGIS2Web) a lot on a previous project (QGIS 2.x era). Especially for sharing a 3D view of contours to CAD specialists. Very useful!
Edit: I used QGIS2ThreeJS. Different plugin, 3D vs 2D, but same principle.
