Folks,
This should be simple but I'm just not finding the answer.
Using an AttributeManager I want to add a value "0.09" to all the existing values in a column of data from a Mapinfo table during translation amongst other things.
The Column is "Average" and is a defined Decimal type field.
The syntax I'm using is clearly wrong.
@Value(Average)+0.09
returns -9999.00 for all values.
What am I doing wrong?
Thanks in advance
Andrew
Best answer by takashi
