I have a set of imagery footprints saved as both a dxf and a dwg. I can load the files into FME Desktop fine but whenever I try to inspect or do any manipulation on the files I get the following error messages.
AutoCAD Reader: An error occurred for dataset 'T:\*************.Footprints_v2.dwg', in function AutoCAD2004Reader::buildPolyFaceMesh. Exception thrown: 'Invalid index' (Invalid index)
AutoCAD Reader: Unsupported 3D raster feature. Skipping entity
I've never worked with dxf or dwg before but I have worked with dgn. Any ideas?
DXF Overwrite color from Block-definition 1 Answer
IFC file conversion to DWG 0 Answers
List all paperspace names in AutoCAD DWG 1 Answer
How to read all Paper Spaces from Acad file? 1 Answer
AutoCAD text background mask 2 Answers
