I am writing out to KML using a FeatureWriter from a File Geodatabase and want to set the geometry of the polygons to not tessellate (default is for tessellation).
I have found the geometry tag but I am unable to figure out how to insert it into the workflow. I need to optimize a large dataset in google earth for less than ideal computers.
Thanks!
