We've just recently begun to adopt the MBTiles format for offline map viewing.
What I expect is a TMS setup, with every tile level at its optimal resolution, i.e. w/o undue pixellation.
I've made some test, but it seems that the MBTiler writer only accepts a raster image, i.e. an already fixed resolution. This results in a pixellated lowest (or highest?) level.
How do I create an MBTiles dataset from my vector map data, with full resolution on all levels ?
The WebMapTiler also expects raster input, so that's not immidiatedly an option.
Any insights are appriciated. Using 2018.1.
Cheers
Hi -- I do know that at this point our MBTiles support is only raster based. We are planning in FME 2019 to add vector support, which will result in the creation of tiles at various zoom levels. This work is already partially done but not yet part of the FME 2019 beta stream.
I *thought* that our raster support also created raster pyramids, but that might just be in Geopackage (I do know its raster support does that). I'll ask those in the know to weigh in.
Would using a 2019 beta work for you?
