I have a problem with the calcul of a sum (expression evaluator, statistic calculator..).
The result is not correct. I make this calcul : 10000+10000+1+100+0.1+0.01 and the result is 20101.109999999997 .
I have this problem in fme 2018 and 2017 but in 2015 the result is correct .
Have you got any idea to solve my problem? Thanks a lot.
Best answer by david_r
