We just upgraded our AutoDesk products to 2019. Is there an FME plugin for Revit 2019...or will the 2018 plugin work with Revit 2019?
Hi @mike_robertson,
I'm sorry, but we haven't tested the plugin in Revit 2019 yet. However, the Revit reader will read IFC files as well as RVZ, so you can use Revit's IFC export in lieu of the FME plugin.
