How to get "Feature Read Summary" with FeatureReader ?
  • 25 June 2018
  • 14 views
Badge +9
  • 101 replies
So I have replaced my FileGDB reader with 2 FeatureReaders (one for spatial, one for non-spatial data)
What I miss now is the "Feature Read Summary" I was used to get from the "real" reader.
Any way to get this summary ?
Best answer by mhab 29 June 2018, 19:25
Badge +30
Hi @mhab
I believe that you can use the transformer Statistic calculator to get the number of features after your Reader.
Danilo
This is a known limitation in FME 2017/2018, there's an idea for improvement here, please consider voting: https://knowledge.safe.com/idea/48251/include-featurewriter-counts-in-the-total-features.html
(Note that the idea concerns both the FeatureReader and the FeatureWriter)
Badge +9
So with the help of StatisticsCalculator, Counter and a TCLCaller I managed to create and write a "Feature Read Summary" of the FeatureReader data into the FME Log file in a way that our automatic statistic extraction works and produces results as it was for a "standard" reader :-))
EDIT: Custom Transformer available through FME Hub (FeatureReadSummary_to_log_writer.fmx)
Screenshot of log file with the generated statistics:
