How can I remove all blank lines from an attribute values.
Blank lines are as shown in next screenshots
Thank you very much.
Best answer by david_r
View originalHello,
View originalHave you tried the AttributeTrimmer?
If you do not specify a trim character, white space is removed (spaces, tabs, newlines, and carriage returns).
I have tried it but didn't get the desired result
I wanna keep spaces but remove only blank lines
Click the button to the right of the "Trim Characters" setting and open the the text editor.
Insert a blank newline and close.
That works for me, anyway.
Thank you !
