Hi all,
I'm trying to parse a cadastral xml file containing lists of points and parcels (containing line sub-lists) in order to reconstruct them into ESRI GDB feature classes. I have been able to create polygons easily when I'm just writing the points to lines, but when I try to create arcs, I not only get snapping issues, but the arcs sometimes appear on the wrong side of the central point.
From the xml I get the center x,y, start/from x,y, end/to x,y and the radius of the arcs. I'm trying to calculate the start, end and sweep angles from this in order to put into 2DArcReplacer and I think that's where I might be going wrong. I can't seem to get the CW / CCW values right here.
Also, when I create the polygon output, the snapping distance has to be lowered, as creating the arcs using 2DArcReplacer seems to change the start / end coords enough so that they don't snap.
I'm attaching both my workbench and sample dataset in case anyone can help.
Thank you in anticipation,
