I am trying to connect to a hosted feature service in our GIS Portal. I am receiving the following error:
..."Check your credentials and try again. The error code from the server was '400' and the message was: 'Unable to generate token.' A fatal error has occurred. Check the logfile above for details"...
I am using our fully qualified domain name with /sharing/rest/generateToken with our service account credentials.
Ideas??
--gary
