When im trying to transform citygml data to ogckml, the FME data inspector does not view the data correctly in 3d view. Instead of separate individual 3D buildings, the data is just a long thin "stick". Data looks correct when viewing with google earth and with FME data inspector in 2D view.
Why is this happening?
Also when trying to convert that kml to wavefront object, the object file comes out as a long stick also.
It seems like every kml file containing 3D data is showing up as along thin stick in fme data inspector when viewed in 3d
Best answer by daveatsafe
