I am trying to retrieve FME Cloud Instance ID to be utilized on the FMECloudInstanceController transformer, but it seems that it is not available through the Server UI.
How am I able to retrieve them? Server API?
Thanks!
John
Another option according to FME Experts is to leverage the FMECloudInstanceLister, which will do the same job in a more streamlined process.
More information here:
I figured it out. There is no easy way to retrieve it through the UI anyway.
You need to leverage FME Cloud API to retrieve it.
Attached is a simple process that will retrieve IDs once you provide the Token.
Setup API using FME Cloud and AWS API 1 Answer
FME Cloud Server trigger on demand? 3 Answers
How can I use the WebSocket Server on FME Cloud? 1 Answer
Workspace tries to run on FME Cloud, but repo doesn't exist? 1 Answer
FMECloud and ADFS 1 Answer
