I am trying to connect to an oracle database. I had a chat with Steve at Safe and I added the connection information in the tnsnames.ora file and added an environmental variable pointing to the tnsnames.ora. I was really hoping that I had done everything that I needed. However, I am still getting the ora-12154 error message. Thank you in advance for your assistance. Attached is the log file from the latest attempt to connect and a screen shot of the environmental variable path.
Best answer by steveatsafe
